Logging Destination IP address Issue
warnerro1
We have an S670 running 7.7.0-500 for web. It is configured transparently and we are routing to an upstream proxy. My issue is when examing the access logs for the destination IP address, all I see is the upstream proxy's IP address instead of the destination address. I've added the necessary custom format to the access logs.
Any assistance would be appreciated.
v/r,
Rob Warner
Erik Kaiser
Hi Rob,
I would recommend that you open TAC support case.
Sincerely,
Erik Kaiser
WSA CSE
WSA Cisco Forums Moderator
Sincerely, Erik Kaiser WSA CSE WSA Cisco Forums Moderator
Vance Kwan
Hi Rob,
I do not have access right now to view the WSA's GUI, but if you go to the log subscription > custom fields, and click the little question mark, do you see any applicable fields that may show the final destination's IP address?  If not, it is not supported, and you can contact TAC and have them file a feature request to include that field.
-Vance
