Objet : Critical <System> IS160.xxx.local: An application fault occurred: ('_coro.pyx coro._coro.sched....
youssougueye
Hi Everybody,
Can somebody explain me what this message means ? Just received it yesterday night from the Ironport Web Security Appliance.
Thanks in advance
bechara33
It is ok If you get a single instances of these application faults, This alert gets generated under a race condition when a process gets interrupted right when a sleep method is called.
You can try to upgrade the Async which will solve the problem if it is frequent,
Thanks for your answer, FYI this is the first time i get this message, an upgrade is available, i've planed to do it but just wanted to know what was the cause of this fault.
Have a good day.
