problems with external ACL rules
JMaartenW
Community Member
Hi, I know this question is probably very common but I am still having issues with understanding ACL's
I've  read so much documentation but its not helping me understand or apply the knowledge to my situation.
basically I have configured a new CISCO 891 router with a number of VPN's connected and a couple of inbound rules to allow rdp and sql traffic to 2 servers on my LAN. to do this I have created ACL 130 and matched it to the inbound  direction of the WAN interface. the confusion is that I would really like the last default rule to be a "deny any any" rule for security. but no matter what I do, even if I create a specific permit rule for web traffic and DNS if I change the last rule to "deny any to any" all my internet connectivity stops working apart from my traffic over the VPN I cannot browse or resolve or ping anything on the internet.
here is my config if anyone can advise me how to ensure my Cisco891 firewall is secure I would be grateful. (PS I've given up trying to use the ZBF as this created even more issues and now only using CLI)
Building configuration...
Current configuration : 9409 bytes
! Last configuration change at 20:53:43 PCTime Mon Apr 28 2014 by admin
version 15.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname LBHCIS891DATA1
boot-start-marker
boot-end-marker
security authentication failure rate 10 log
security passwords min-length 6
logging buffered 51200 errors
logging console critical
enable secret 4 MHpke6/RnYLNL/fAD5EKDxml.aj8Sr4IJfubMQjIoB2
enable password 7 08331D1F074D031A39
aaa new-model
aaa authentication login local_auth local
aaa authentication enable default enable
aaa session-id common
memory-size iomem 10
clock timezone PCTime 0 0
clock summer-time PCTime date Mar 30 2003 1:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-3955790181
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3955790181
 revocation-check none
 rsakeypair TP-self-signed-3955790181
crypto pki trustpoint TP-self-signed-3612796534
 subject-name cn=IOS-Self-Signed-Certificate-3612796534
 rsakeypair TP-self-signed-3612796534
crypto pki trustpoint test_trustpoint_config_created_for_sdm
 subject-name [email protected]
 revocation-check crl
crypto pki trustpoint TP-self-signed-1280197465
 subject-name cn=IOS-Self-Signed-Certificate-1280197465
 rsakeypair TP-self-signed-1280197465
crypto pki certificate chain TP-self-signed-3955790181
crypto pki certificate chain TP-self-signed-3612796534
crypto pki certificate chain test_trustpoint_config_created_for_sdm
crypto pki certificate chain TP-self-signed-1280197465
vlan ifdescr detail
no ip source-route
no ip gratuitous-arps
ip cef
no ip bootp server
ip domain name <Internal domain name>
ip name-server 8.8.8.8
ip name-server 172.24.4.13
ip name-server 172.24.16.13
ip name-server 172.24.16.15
ip inspect log drop-pkt
login block-for 5 attempts 10 within 5
no ipv6 cef
parameter-map type inspect global
 log dropped-packets enable
 max-incomplete low 18000
 max-incomplete high 20000
 spoofed-acker off
license udi pid CISCO891-K9 sn FCZ1813C2XL
username admin privilege 15 secret 4 MHpke6/RnYLNL/fAD5EKDxml.aj8Sr4IJfubMQjIoB2
redundancy
ip tcp synwait-time 10
no ip ftp passive
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
crypto logging ezvpn
crypto isakmp policy 20
 encr 3des
 authentication pre-share
 group 2
crypto isakmp key ******************* address (PEER IP)
crypto isakmp keepalive 10 5
crypto isakmp aggressive-mode disable
crypto ipsec security-association lifetime seconds 86400
crypto ipsec transform-set ADAPTVPN esp-3des esp-sha-hmac
 mode tunnel
crypto ipsec profile ADAPT_IPSEC_POLICY
 set transform-set ADAPTVPN
crypto map ADAPTVPN 200 ipsec-isakmp
 set peer <<VPN PEER IP>
 match address VPNSITE
interface Null0
 no ip unreachables
interface FastEthernet0
 description VLAN 1 Trunk port
 switchport mode trunk
 no ip address
interface FastEthernet1
 description VLan 1 Access port
 no ip address
interface FastEthernet2
 description Vlan 1 Access port
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 no ip address
interface FastEthernet5
 no ip address
interface FastEthernet6
 description VLAN 50 access port
 switchport access vlan 50
 no ip address
interface FastEthernet7
 description VLAN50 trunk port
 switchport trunk native vlan 50
 no ip address
interface FastEthernet8
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0
 description WAN 1 interface for LBHETH-WAN$$ETH-WAN$
 ip address <Wan int Public IP add> 255.255.255.192
 ip access-group 130 in
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 crypto map ADAPTVPN
interface Vlan1
 description $FW_INSIDE$
 ip address 172.24.16.241 255.255.252.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nbar protocol-discovery
 ip flow ingress
 ip flow egress
 ip nat inside
 ip tcp adjust-mss 1452
interface Vlan50
 ip address 172.17.116.241 255.255.255.0
 ip nat inside
interface Async1
 no ip address
 encapsulation slip
 shutdown
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-top-talkers
 top 10
 sort-by bytes
 cache-timeout 10000
ip nat inside source route-map SDM_RMAP_1 interface GigabitEthernet0 overload
ip nat inside source static tcp 172.24.16.19 1433 <Wan int Public IP add> 1433 extendable
ip nat inside source static tcp 172.24.16.25 3389 <Wan int Public IP add> 3389 extendable
ip route 0.0.0.0 0.0.0.0 <Wan int Gateway>
ip access-list extended VPNSITE
 remark CCP_ACL Category=5
 remark access all sites
 permit ip 172.24.16.0 0.0.3.255 172.24.0.0 0.0.255.255
 remark voip
 permit ip 172.24.16.0 0.0.3.255 172.17.0.0 0.0.255.255
 remark webmail
 permit ip 172.24.16.0 0.0.3.255 192.168.102.0 0.0.0.255
 remark a cloud
 permit ip 172.24.16.0 0.0.3.255 192.168.25.0 0.0.0.255
 remark a cloud test
 permit ip 172.24.16.0 0.0.3.255 192.168.26.0 0.0.0.255
 remark a cloud public
 permit ip 172.24.16.0 0.0.3.255 192.168.27.0 0.0.0.255
 remark voip
 permit ip 172.17.116.0 0.0.0.255 172.17.0.0 0.0.255.255
 permit ip 172.17.116.0 0.0.0.255 172.24.0.0 0.0.255.255
ip sla auto discovery
logging trap debugging
logging facility local2
logging host 172.24.4.51
access-list 102 remark CCP_ACL Category=2
access-list 102 remark acloud public
access-list 102 deny   ip 172.24.16.0 0.0.3.255 192.168.27.0 0.0.0.255
access-list 102 remark acloud test
access-list 102 deny   ip 172.24.16.0 0.0.3.255 192.168.26.0 0.0.0.255
access-list 102 deny   ip 172.24.16.0 0.0.3.255 192.168.25.0 0.0.0.255
access-list 102 remark oa.accessnet.co.uk
access-list 102 deny   ip 172.24.16.0 0.0.3.255 192.168.102.0 0.0.0.255
access-list 102 remark voip
access-list 102 deny   ip 172.24.16.0 0.0.3.255 172.17.0.0 0.0.255.255
access-list 102 remark access all sites
access-list 102 deny   ip 172.24.16.0 0.0.3.255 172.24.0.0 0.0.255.255
access-list 102 deny   ip 172.17.116.0 0.0.0.255 172.17.0.0 0.0.255.255
access-list 102 deny   ip 172.17.116.0 0.0.0.255 172.24.0.0 0.0.255.255
access-list 102 permit ip 172.24.16.0 0.0.3.255 any
access-list 102 permit ip 172.17.116.0 0.0.0.255 any
access-list 130 remark EXT_ACL
access-list 130 permit ip 172.24.0.0 0.0.255.255 172.17.116.0 0.0.0.255
access-list 130 remark voip
access-list 130 permit ip 172.17.0.0 0.0.255.255 172.17.116.0 0.0.0.255
access-list 130 remark acloud public
access-list 130 permit ip 192.168.27.0 0.0.0.255 172.24.16.0 0.0.3.255
access-list 130 remark acloud test
access-list 130 permit ip 192.168.26.0 0.0.0.255 172.24.16.0 0.0.3.255
access-list 130 permit ip 192.168.25.0 0.0.0.255 172.24.16.0 0.0.3.255
access-list 130 remark oa.accessnet.co.uk
access-list 130 permit ip 192.168.102.0 0.0.0.255 172.24.16.0 0.0.3.255
access-list 130 permit ip 172.17.0.0 0.0.255.255 172.24.16.0 0.0.3.255
access-list 130 remark access all sites
access-list 130 permit ip 172.24.0.0 0.0.255.255 172.24.16.0 0.0.3.255
access-list 130 permit udp host <VPN PEER IP> host <Wan int Public IP add> eq non500-isakmp
access-list 130 permit udp host <VPN PEER IP> host <Wan int Public IP add> eq isakmp
access-list 130 permit esp host <VPN PEER IP> host <Wan int Public IP add>
access-list 130 permit ahp host <VPN PEER IP> host <Wan int Public IP add>
access-list 130 permit tcp host <a webserver> host <Wan int Public IP add> eq 1433 log
access-list 130 permit tcp any host <Wan int Public IP add> eq 3389 log
access-list 130 permit ip host <a Public Ip I need> host <Wan int Public IP add>
access-list 130 permit tcp any host <Wan int Public IP add> eq www
access-list 130 permit tcp any host <Wan int Public IP add> eq 443
access-list 130 permit tcp any host <Wan int Public IP add> eq domain
access-list 130 deny   tcp any host <Wan int Public IP add> eq 1433
access-list 130 permit icmp any host <Wan int Public IP add>
access-list 130 permit ip any any
no cdp run
route-map SDM_RMAP_1 permit 1
 match ip address 102
control-plane
mgcp profile default
line con 0
 login authentication local_auth
 transport output telnet
line 1
 modem InOut
 speed 115200
 flowcontrol hardware
line aux 0
line vty 0 4
 exec-timeout 30 0
 privilege level 15
 password 7 09554B1A
 transport preferred ssh
 transport input ssh
 transport output ssh
scheduler interval 500
ntp update-calendar
ntp server 0.uk.pool.ntp.org
end
You need a firewall-config that allows the return-traffic:
ip inspect name FW tcp router-traffic
ip inspect name FW udp router-traffic
ip inspect name FW icmp router-traffic
ip inspect name FW ftp
int gig0
  ip inspect FW out
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
