Problems with URLs redirected to HTTPS with port (:443)
arrojas.d
Visitor
The proxy is blocking a URL that I have in a custom category, and the category is "pass through" in the policies. This happens to me with several URLs that appear in the end port: 443. Does anyone know what the problem is? What I have had to do is bypass because it does not work through the WSA.
balaji.bandi
Look at the Decryption policy - UAproNT_HTTPS - how it was configure and tweak that polices.
Since we do not what that policy configured, it is hard to suggest here.
Do you see issue https://site (with out 443 ?)
BB
The URL is in a custom category that is pass through (Image attached), if I make a policy trace the result is that the query is completed without problems.
These problems I have only seen when the port is added to the end of the domain.
is this possible to post the Logs from console, using grep. also can you give screenshot global white ?
BB
