Shutdown Interface command Ironport
Mafiaboy401
Level 2
Level 2
Hi everybody!
Ironport has a "shutdown" command to disable the interfaces ?
Thanks.
Christian Rahl
Level 6
Level 6
The only way to disable interfaces is by removing the interface from the configuration. There is no "shutdown" command for interfaces.
You can remove interfaces through both the CLI and GUI.
To do it in the gui go to "Network" -> "Interfaces" -> "Edit".
Once you do that remove all the information from whatever interface you want to disable.
The cli is a little bit easier. Type the following commands in order.
"interfaceconfig" -> "delete" -> Interface # -> Answer "y"
Christian Rahl
Customer Support Engineer
Cisco IronPort - Web Security Appliances
Cisco Technical Assistance Center RTP
United States Ironport: 1-877-641-IRON (4766)
Christian Rahl
Level 6
Level 6
Christian Rahl
Thanks Christian!
Atazazuddin Shaikh
Shutdown is used to ³power off² the WSA gracefully from the CLI
Zack
On 6/12/12 1:18 PM, "Mafiaboy401"
Valter Da Costa
No. We have no shutdown command available.
If you are interested in having this feature, please open a case and we will
provide you with a Feature Request form.
Valter
On 6/12/12 2:18 PM, "Mafiaboy401"
