02-09-2021 07:37 AM
connection establishing from SMA to WSA shows an error says (timeout), i ave checked all the configuration steps and its all done
Screenshot from SMA capture attached
02-09-2021 07:47 AM
What is the WSA IP and SMA IP address ?
make sure you have reachability and right route to use correct interface ?
WSA are you trying to connect M1 interface ? what is the IP as i asked top.
=====️ Preenayamo Vasudevam ️=====
02-09-2021 08:04 AM
WSA management IP is 172.25.201.26
SMA Management IP is 10.255.111.150
SSH port is allowed between them in and out
02-09-2021 09:15 AM - edited 02-09-2021 09:16 AM
I should have asked before, is this new setup or after upgrade not working ? what is the Version of SMA and WSA please ?
check also bug :
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvg92884/?rfs=iqvred
