Splitting Licenses between two WSAs?
cpaquet
Level 4
Level 4
Is it possible to split, as an example, a WSA-AMP-1Y-S1 license, between two WSAs?  I'm pretty sure not, but need to provide a definite answer to my boss 😉    The minimum quantity is 100 users.  So, if we have two sites with WSAs, could we have 50 seats on one WSA and 50 on the other?  (again, I'm pretty sure it's no, even with Smart License).
Thanks.
Most of the WSA feature licenses are per user... so if you have 100 users in your company you should be able get the second box provisioned for it.
If you're using VMs, you can spin up as many vm's as you like, in whatever size you need for those same 100 users... you just apply the same license file to them.
