Syslog configuration certificate issues
yato231
Community Member
Hello everyone,
I am trying to configure a nexus (nx os 9.3) to send its logs to syslog server over tls.
logging server 10.10.10.1 5 port 6514 secure use-vrf management
 When I try to configure the trustpoint I get the error "certificate is missing basic constraints extension , could not perform CA authentication".
crypto ca authenticate my-ca
I am pasting the root, intermediate and server certificates (pem) after this command. I have checked use openssl that the root and intermediate certs do have the basic constraints extension, and CA=true.
Also if I only paste the root and intermediate certificate then I don't have this error. This leads me to think that in the trustpoint I can only have CA certs, not the server certs. Is this true? and in that case where should I import the server cert? should it work without the server cert? Previous I worked on firewalls and there we had to import the whole chain from the server, intermediate and root.
Thanks in advance.
yes if the router acting as CA and syslog trust that certs
BB
5 Replies 5
balaji.bandi
Syslog server and nexus device should trust same CA for them to communicate.
https://www.syslog-ng.com/technical-documents/doc/syslog-ng-open-source-edition/3.17/administration-guide/55
BB
Thanks for the link. So if I understand correctly, we don't need to add the certificate of the syslog server. It should work if the CA certificate installed on the nexus device refers to the CA originally used to create the syslog server certificate.
BB
Show crypto ca trustpoint
Share this
MHM
yato231
Community Member
#show crypto ca trustpoint
trustpoint: root-ca key-pair:
revokation methods: none
