Transfer SMA to virtual And CM mismatch
I have a physical SMA 11.0.1-161 and WSAs 11.7.1-020
I have set a new virtual SMA 13.8.1-052 and I would like to transfer the config.
I set up a temp SMA same version with physical in order to transfer the config and perform the updates.
I successfully loaded the config.
When I upgraded to the latest version the configuration master(10.5) was gone.., because it only supported newer CM.
What should I do to transfer the config to the latest version;
Thanks and regards,
Konstantinos
balaji.bandi
You need to re-intialise the config, 13.X will not able to read the old 11.X config, So WSA need to 12.X
BB
Ok
So I will have to connect the WSA to re-initialise?
Or should I upgrade first to a version previous that 13.8?
I have tried different versions to upgrade ( 13.8.1-052 which is the final I want to go and 13.6.2-058) and when I upgrade the CM is gone
In the current version 11.0.1-161, I have also CM 11, but I cannot initialize it from the CM 10.5 that I have
I need your help to understand how will I transfer the CM to the upgraded version of SMA.
Konstantinos
