want to block webex in wsa
Asim Afzal
I want to block webex  in WSA .kindly advise how we can acomplish this
Chris Illsley
Level 3
Level 3
Hi Asim,
Go to yuor Access Policies in the WSA.
Open up the Applications section of the policy you are applying it to, under Presentations/Conferencing you have the option to block Webex.
Chris
Also if you are using WCCP, make sure that WebEx is not bypassed under Web Security Manager > Bypass Settings.
-Vance
