WSA - 7.5.0-833 - saveconfig and reverse question
herve.leon
I've noticed a failed reverse question when using the CLI "saveconfig" command on WSA, version 7.5.0-833
It doesn't appear on ESA 7.5.0 version 7.6.1-022 nor when using the GUI
Prior to version 7.5
> saveconfig
Do you want to include passwords? Please be aware that a  configuration without passwords will fail to be loaded with loadconfig.  [N]
If you  press Y, the password is not masked.
Since version  7.5 :
>saveconfig
Do you want to mask the password? Files with masked passwords cannot be loaded using loadconfig command. [Y]>
              This question is the opposite, so logically, if the answer is NO, you should get the clear text  password.
                But, If you answer NO, the password is masked (<enc_password>*****</enc_password>)
               If you answer YES, it works.
Is there a hotfix or an updated version fixing this ?
Herve
Erik Kaiser
Hi Herve,
Thank you for submitting this information to me. I will test this in my lab and provide you with a bug number.
Sincerely,
Erik Kaiser
WSA CSE
WSA Cisco Forums Moderator
Sincerely, Erik Kaiser WSA CSE WSA Cisco Forums Moderator
