WSA blocks skype business traffic
mseck0001
Hi All,
We install WSAv for a POC. Unfortunately, the appliance blocks skype business traffic.
How to issue this problem? Kindly help!
Thank you in advance!
Skype for Business, aka "Lync"?
Put the IPs of your Edge boxes and the web IP of the server or load balanced IP in the Web Security Manger/Bypass Settings.
Hello Ken,
Thank you for your reply.
I will try and get back to you.
Thank you!
tahscolony
If you are using WCCP, you could create an ACL with the Skype server IP ranges and use that to bypass WCCP. Place this rule above the WCCP redirect rule.
Hello Tahscolony,
Thank you for your reply. Let me try this option.
Will revert.
Thank you!
