WSA Etherchannel
lcaruso
Level 6
Level 6
Anyone know for certain if S170 can do Etherchannel to a Cisco switch?
Thanks.
No, you can't create etherchannel.
If you want to have HA then I'd recommend to purchase additional appliance and install it as a:
- second wccp member if transparent redirection mode is configured
- HA member if running explicit forwarding mode (this feature has been added recenty in asyncos)
You can also run secondary appliance as a virtual appliance (supported on esxi platform) as long as you're running same asyncos version on both appliances.
And connect one appliance on one switch and other appliance on second switch.
Hope this solves your problem..
