WSA Router Identifier is taking highest IP:DMZ instead of inside
WSA---->L3_SWITCH----->(inside)ASA(dmz)----
++ASA is not redirecting packets to WSA however i see The HELLOS are exchanged.
++L3 switch has a route to reach ASA DMZ interface.
++In WSA i have configured both inside and DMZ ip under WSA>transparent redirection>router ip address
WCCP-PKT:S00: Received valid Here_I_Am packet from 10.101.68.200 w/rcv_id 00000043
WCCP-PKT:S00: Sending I_See_You packet to 10.101.68.200 w/ rcv_id 00000044
Global WCCP information:
Router information:
Router Identifier: 192.168.243.254
Protocol Version: 2.0
Service Identifier: web-cache
Number of Cache Engines: 1
Number of routers: 1
Total Packets Redirected: 0
Redirect access-list: wccp_traffic
Total Connections Denied Redirect: 0
Total Packets Unassigned: 0
Group access-list: wccp-server
Total Messages Denied to Group: 0
Total Authentication failures: 0
Total Bypassed Packets Received: 0
Could you pls let me know if iam missing something
Appreciate your help!
11 Replies 11
What version of ASA code are you running?
I seem to remember having an issue like this on 8.2 or 8.4???? I'll go digging in my tickets...
Thanks for responding..
version:- 9.8(2)
Please feel free to let me know if you need any kind of information reg setup or config
FYI here is the config in ASA:-
WSA----L3_switch-----(inside)ASA(dmz)
WSA IP:-10.101.68.200
ASA inside ip:-10.101.71.65
ASA DMZ ip:-192.168.243.254 ---->Highest ip address
Configuration:-
wccp 90 redirect-list wccp_traffic group-list wccp-server
wccp interface inside 90 redirect in
access-list wccp-server extended permit ip host 10.101.68.200 any
access-list wccp_traffic extended permit tcp host 10.101.64.112 any eq www
access-list wccp_traffic extended permit tcp host 10.101.64.112 any eq https
access-list wccp_traffic extended deny ip any any
Show command output:-
###sh wccp 90
Router information:
Service Identifier: 90
Total Connections Denied Redirect: 1675
###sh wccp 90 detail:-
WCCP Cache-Engine information:
Web Cache ID: 10.101.68.200
State: Usable
Initial Hash Info: 00000000000000000000000000000000
Assigned Hash Info: 00000000000000000000000000000000
Hash Allotment: 0 (0.00%)
Connect Time: 03:00:16
###sh wccp 90 view
WCCP Routers Informed of:
192.168.243.254
WCCP Cache Engines Visible:
10.101.68.200
WCCP Cache Engines NOT Visible:
-none-
##Dubugs hello packets
WCCP-PKT:D90: Sending I_See_You packet to 10.101.68.200 w/ rcv_id 00000417
WCCP-PKT:D90: Received valid Here_I_Am packet from 10.101.68.200 w/rcv_id 00000417
Configuration on WSA:-
Allow GRE only  for forward and return packet
Allow Hash only
router ip address: 192.168.243.254, 10.101.71.65
Looking at mine in production, the router identification is NOT the interface that is connected.
Its the highest IP on the ASA.   Did a little digging, and I'm pretty sure that's just how the ASA works. (see my show wccp below)
My bug was in 9.1.1 (CSCue02226)... unrelated...
My WCCP config doesn't have a server list, I just use the password.
Are you trying to surf from 10.101.64.112
    Router information:
 Router Identifier:                   172.25.0.1
 Total Packets Redirected:            36880541
 Redirect access-list:                WCCP_Redirect
 Total Connections Denied Redirect:   609
 Total Packets Unassigned:            658
 Group access-list:                   -none-
 Total Bypassed Packets Received:     65925
yes. I'm trying to surf from 10.101.64.112.
Could you tell me if it using DMZ IP or Inside IP to contact WSA?
because the HELLOS are exchanged, but probably the engine is rejecting the wccp GRE packets from the router id or viceversa.
The communication would be over the inside IP/port.
WSA-10.101.68.200---->L3_switch----->(inside-10.101.71.65)ASA(dmz-192.168.23.254)
I have turned on captures in ASA inside interface
I see WSA is communicating with both Inside and DMZ.
First capture:- WSA--communicating with---->Inside interface of ASA
1: 05:47:42.409005 10.101.68.200.2048 > 10.101.71.65.2048: udp 120
2: 05:47:42.409082 10.101.71.65.2048 > 10.101.68.200.2048: udp 140
3: 05:47:52.424569 10.101.68.200.2048 > 10.101.71.65.2048: udp 120
4: 05:47:52.424630 10.101.71.65.2048 > 10.101.68.200.2048: udp 140
5: 05:48:02.380153 10.101.68.200.2048 > 10.101.71.65.2048: udp 120
6: 05:48:02.380214 10.101.71.65.2048 > 10.101.68.200.2048: udp 140
Second capture:-WSA---communicating with--->DMZ interface of ASA -===>BOLOCKED
packet tracer shows:- Drop-reason: (no-route) No route to host
1: 05:47:32.393366 10.101.68.200.2048 > 192.168.243.254.2048: udp 148
2: 05:47:42.408975 10.101.68.200.2048 > 192.168.243.254.2048: udp 148
3: 05:47:52.424523 10.101.68.200.2048 > 192.168.243.254.2048: udp 148
So why WSA is talking to DMZ interface then? As far as i know by design we cannot talk/communicate to ASA's other interface IP.
What does the configuration on the WSA look like? Just because the ASA says that's its ID is the DMZ ip, you still configure the WSA to do WCCP with the ip of the ASA inside interface.
I have Both inside and DMZ IP address in WSA
The wsa should only have the ASA inside ip...
I gave both inside and DMZ ip address in WSA
