Add local user on many endpoint true Webex Control Hub
Kenni Jensen
Hey
I want to add a local admin user to many Cisco Webex Room Kits true Connect Hub.
I can make template and push out.
I can add a user on one endpoint at the time.
I want to do it on all our endpoints.
Could be the username should be "localuser" with admin rights
Can that be done ?
/Kenni
ahmea23
Hi Kenny,
Please try the following steps:
1. Log in to Webex Control Hub and select the Endpoints tab.
2. Select the endpoint you want to add a local user to.
3. Click on the Local Users tab and then click on the Add button.
4. Enter the username and password for the new user, then click Save.
5. The new user will now be added to the endpoint and can be managed from within Webex Control Hub.
Regards.
Ahmed E
