Auto Start webex button grayed out
steven-dayquist
Community Member
We want to disable the Auto start across our physical endpoints for Webex Teams. Currently, our end users are not able to disable it as the "Start webex when Windows Starts" button is checked and grayed out. I tried removing the Cisco Spark key from this location in the registry with no luck. HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
Ideally, I would like to blanket uncheck the box across just our physical endpoints, perhaps via SCCM. However, if we can at least allow our end users to enable or disable the option, that would work as well. Can anyone help point me in the right direction? Thank you in advance.
patric79
Community Member
I have this problem as well.  Just checking if you had found an effective fix yet.  Thank you.
The only fix we found was to push the software out to all our physical endpoints and adjust the parameters of the install to disable auto start. I never did find a way to simply allow the end user to enable or disable auto start.
