Cant find PN for items - Webex Room
Good Morning gentlemen,
I would like to receive the correct Part Number for the items listed below
Wall Mount for Cisco Spark Kit (CS-KIT-WMK-)
Screen Mount for Cisco Spark Kit (CS-KIT-SMK-)
IP Communications Center C Eng (AS-IPC-CNSLT-L2)
thx a lot
Jaime Valencia
If you're with a Cisco partner, you should reach out to PH for assistance with PNs/ordering.
If you're an end user/customer, you should reach out to a Cisco partner/distributor for this.
java
if this helps, please rate
