Cisco Jabber & WebEX meetings.
kartik.shah1
Hi Community,
I was looking for the solution where i want to use Cisco Jabber as standalone with CUCM & want to integrate with Cisco webEX meetings (on-premise)?
Can anyone guide for such type of solution?
Does Cisco has a solution similar to Microsoft teams?
Thank You.
Nüüül
For the first one I cannot help, sorry. but regarding MS Teams:
not exactly the same Features like shared file editing and so, but "Cisco WebEx Teams" is looking in the same direction, i think.
Thanks for responding.
Can you also help with the Licensing for Webex teams?
AFAIK:
It depends on what you want to use. only messaging might be free, but when you want to use any integration with your Active Directory or so you will need a webex subscription likely on base per user per month https://www.webex.com/de/pricing/index.html
These are only assumptions taken from the website www.webex.com/
Best would be to talk to cisco´s sales reps. They can tell you, what you need.
