cisco webex
uttammudgal
Community Member
does cisco webex support hard endpoints.
You will need to be a little more specific about which "Webex" you are referring to, and what you mean by "support".  A better description of what you are trying to achieve would allow us to provide you with a more precise answer.
Most of the newer cloud based or hybrid offerings will allow you to connect using a hardware (SIP or H.323) endpoint, but if you are referring to some of the older Cisco Webex Meeting Server on-prem solutions, then this is not always possible, or there are limitations.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Mike_Brezicky
You might want to be more specific as to what type of endpoints, but in shot yes - Webex supports integration with all SIP and H.323 based video endpoints. Additional configuration may be needed to get the endpoints to connect to Webex, but they are capable of connecting.
