02-27-2025 08:59 PM
Any update on this? I Have had this problem for months now.
07-03-2025 01:35 PM - edited 07-03-2025 01:51 PM
- I cannot reproduce the issue with the release 45.7. Important, you have to signal the app that the word is finished with a blank.
- 44.9 is a normal release, no slow channel release, means 44.9 will not receive a bugfix. The solution will be always to upgrade to a newer minor release.
- 44.9 is since 1st July End of Life Reference: https://help.webex.com/en-us/article/ne3khsm/Webex-App-support-policy
07-02-2025 09:40 PM
@richdav - as a Cisco Employee, you will likely have more luck reaching out to the BU through your internal channels than posting here in a Community (Customer) supported forum.
Please remember to mark helpful responses and to set your question as answered if appropriate.
