CSCwn72771 - Webex app not scaling correctly on vertical screen
lkubat
Not sure - will this be fixed?
This basically needs me to buy a new screen if I want to continue using webex like I did in previous versions.
The problem does not go away with the suggested workaround - IF you add a TAB to the space (next to "Messages" "People" "Content" "Meetings" etc...) this space becomes basically useless in 1080x1920 because of this bug introduced somewhere late 2024 - early 2025.
I will never be able to scale any space past the pin i the screenshot - which makes the text in messages cut and unreadable.
0 Replies 0
