Trying to use a .csv to turn on the switch \User\Hybrid services\Calendar services\Administrative authorization. ("Microsoft Exchange / Office 365" is already set).
From the downloaded users csv I find that the column/value "Hybrid Calendar Service (Exchange)" is set to "True" for those I've already set manually. So I make a CSV containing the columns "First Name", "Last Name,User ID/Email (Required)" and "Hybrid Calendar Service (Exchange)" for a handful of test users and import it in the WCH, it imports without errors and claims the records updated.
But no, checking afterwards shows none have been set. Ideas? Is there also another column that is needed here? Thanks!
EDIT: Problem solved. It was not a real problem, it was me who uploaded a wrong/unedited CSV... Uploading the correct one worked as it should.
