E2EE End to End Encryption, Enable or On By default?
RoyalMount
I'm a new WebEx user, evaluating a change from Zoom to WebEx for my org.
In Zoom there was a setting to enable E2EE, is there a setting to enable this in WebEx? Or is it baked in?
I saw a reference to enabling "E2EE for all connections," in the knowledge base, but that requires an organizational account.  Is this different than E2EE for the desktop / mobile (ios, android app) users?
Is E2EE available in the free product?
Thanks for your help!
Since Cisco couldn't answer the question, I've finally figured it out.
Webex uses standard encryption unless you enable End-To-End Encryption.  To enable end-to-end encryption go to
Click on your user. A window pops out on the right
Select meeting (cisco webex meetings)
Select your Meeting site (containing your initials and numbers, etc.)
Change from PRo Meeting to Pro -End-to-End Encryption
WeiKwongOng5555
I have this doubt too, is E2E encryption enabled by default for Webex?
Suggest you review this document that covers security
https://www.cisco.com/c/dam/en/us/products/collateral/conferencing/webex-meeting-center/white-paper-c11-737588.pdf
java
if this helps, please rate
Unfortunately that document doesn't seem to answer the OP's question.
