How to Enable alerts in Webex Control Hub for Device registration
Yasir@1995
Hello All,
Is there any possibility to set alerts for cloud registered endpoints for the registration status?
Suppose the device registration was lost due to a network issue, or any kind of configuration issue. The same should receive as an alert. Anyone can suggest, that I have checked on My control hub and I can see that there are some options for meetings and callings. Apart from that is there any alternate way to achieve the above scenario?
dtibbe
There is a beta feature My Alerts notifying if a devices has issues. Check if the option is present in Devices->my Alerts
dtibbe
