how to know which codecs are most often in the same calls as other
sashankhapale
Is there a way to identify which codecs are most often in the same calls as other codec.
For example Codec A and Codec B are in 80% of the same call.
Would like to know if any report or dashboard in Cisco webex / Control Hub Shows the data required
Or maybe there is way to combine data from 2 or more reports to find out the necessary data.
Hi ,
Not sure about the possibility of above feature but in Analytics and Troubleshooting page you will be able to get the information about audio usage and other details. Please refer below link for more info:
Revamped Meetings Analytics Audio Page
