how to use DX 80 with mouse and keyboard
maxmaximus
I bought a DX80 with a defective touchscreen and I'm trying to use it with a mouse and/or keyboard, but none of these are working. Is there a way to configure DX80 to use a USB mouse?
Software version: ce 9.2.4 4de75bc 2018-02-20
Thank you,
Max
Hi @luis_cordova and thank you for your reply,
The topic you have mentioned is related to Bluetooth devices.
I'm trying to use the USB ports, not to connect a Bluetooth keyboard or mouse.
Best,
Max
The DX80 can only be used with a mouse and a keyboard when it is running the old discontinued Android software, not with the new CE software loads.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
