Productivity Tools Template
WayneCurley3100
Frequent Visitor
Frequent Visitor
Is there a way to permanently change the "attendees can join" time from 5 minutes to 15 minutes on the productivity tool used in Outlook?
Currently you have to manually change the value from 5 to 15. Is there a template I can update for this so that the default will be 15 rather than 5
Mike_Brezicky
Generally, this would need set by the admin in Control Hub (or site Admin). They can creat is as a global setting or a new MC Template.
