Slido and WebEx Administration
ToneE
Can Slido be enabled on a per user basis or must it be enabled organisation wide?
zospanov
Hi ToneE,
Slido integration should be enabled on Org wide level by Org Admin.
You should have the toggle in Control Hub under Apps section. Please see the screenshot.
zospanov
Hi ToneE,
This is useful thanks - do you know if Slido is reportable from with CH? Be good to see how a customer is using it and also who.
