Webex Control Hub & API Support
ruatkin
Greetings, does Control Hub have the ability to send troubleshooting metrics (latency, jitter, packet loss, etc) via an API/webhook?
josviz
Hello @ruatkin ,
You can do it using the following API:
https://analytics.webexapis.com/v1/meeting/qualities
Refer to:
Get Meeting Qualities
https://developer.webex.com/docs/api/v1/meeting-qualities/get-meeting-qualities
Also, note that API support is requested directly thought:
https://developer.webex.com/support
Please rate if it's “Helpful”.
If this answered your question please click “Accept as Solution”.
dtibbe
Nope, you may only utilize the reports api if there is a report fitting to your needs..
There is also the Meetings Quality API: https://developer.webex.com/docs/api/v1/meeting-qualities
