Webex hub - MS teams CVI
Mark
Is there a way to know which webex organization a MS tenant ID is linked to? We are trying to setup video integration on our hub but it it seems that our MS tenant ID is linked to a different organization and unfortunately TAC can’t do a massive search.
Thank you,
josviz
Hello @Mark ,
If I'm understanding correctly you are trying to check from MS Teams if CVI is already configured? If so, you will need to run the following PowerShell command:
Get-CsVideoInteropServiceProvider
Refer to:
https://docs.microsoft.com/en-us/powershell/module/skype/get-csvideointeropserviceprovider?view=skype-ps
The TenantKey/Video Address will tell you which Webex Organization is using the integration.
[WebexOrg]@m.webex.com
Please rate if it's “Helpful”.
If this answered your question please click “Accept as Solution”.
