Webex control hub - Azure AD Wizard - Groups synchronization
giorgiosecci
Hi all, I have set up Azure AD Wizard App in Control Hub and I would like to synchronize group objects. I already enabled the "Sync group objects" option, but on Sync Summary the group is on "To be synced" status.
Anyone knows what this status means and how can I solve it?
Jose Nerio
I think there was a bug with syncing groups. It was recently fixed. Are you still having the issue?
Jose Nerio
Hi Jose, I think you are right because groups are now synced. I am waiting for a confirmation on the bug from Cisco support. Thanks
Ratheesh Kumar
Hi there
I am wondering did you check for Adsync services and try restarting them.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts and if applicable mark "Accept as a Solution"***
Hi Ratheesh, I am using an Azure AD sync, the Directory Connector on-prem is not involved.
G.
