Webex Managed Gateway - how does it work with VRFs?
pescla
I am following the Webex Managed Gateway Guide (https://help.webex.com/en-us/article/xftgfc/Enroll-Cisco-IOS-managed-gateways-to-Webex-Cloud#Cisco_Concept.dita_f801e8aa-f9f6-41d5-86fa-ac351250e7b5) but after completing the steps to install the connector i am stuck. The connector is not reachable - the cause of this is that the connector script creates a static route for the connector IP that points to the VirtualPortGroup. But the problem is that it creates it in the default VRF, so it doesnt do anything for our setup (which is using a VRF on the external interface where the connector lies). I tried setting the same static route just for the VRF but that doesnt work - the target needs to be an IP or a p2p interface, and the VPG created by the script does not have an IP.
Was this setup tested with VRFs or do i just have to try things out here?
0 Replies 0
