WebEx Room Kit Plus // 3rd Party External Audio Solutions
andyflag31
Hello all!
As the title suggest I am looking for a solution for the WERK+, specificaly integrating a 3rd party amplifier and ceiling speakers.  I am used to the same set up with the SX80, but have heard of issues with the WERK+ under similiar builds.  The forums suggest that echo and low audio outputs are observed with the 3.5MM external output and 3rd party builds.  Looking to avoid that!
Thanks in advance!
Andy
I can't say whether or not it will work for you, but one thing to watch with third party amps and ceiling speakers is compatibility with Cisco Proximity. Generally speaking, if the room isn't too big you're likely going to have better audio quality and a much simpler setup with the Quad Cam speakers anyway, although sometimes you can't avoid ceiling speakers.
Thanks Nick.  That was also the recommendation from Cisco.
Any other recommendations for ceiling speakers/amp would be awesome!
Bumping thread.
Please help!!
