Webex Teams - Rename a Space
Roray Stewart
Has anyone else noticed or are aware of an issue with trying to rename a Webex Teams Space on the client app? From the web (teams.webex.com) it works fine.
I've just had the latest version (3.0.15711.0) pushed to my client so have updated and re-tested and the issue is still present.
husali
Hi Roray Stewart,
You should be able to rename any space that is not the General space of a Team. Anyone in the space should be able to do so unless it is a moderated one, in which case only the moderator(s) can change the name.
https://help.webex.com/en-us/2xi5rv/Webex-Teams-Update-a-Team-Name
If you are still not able to rename the space after editing it from the Web application, I suggest opening a TAC case.
Hussain
Response Signature
husali
Hi Roray Stewart,
Hussain
Response Signature
TAC have confirmed the issue and that it is a bug with a currently Open status - https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvu84998
Thanks for sharing @Roray Stewart .
Hussain
Response Signature
