Camera does not work with background image
eric.dcvieira
Visitor
My camera does not show me in front when I select a background image, and with defocus. Someone with same problem?
dmcinnis
Community Member
Issue resolved. Updated camera firmware from lenovo.com, removed all apps that used the camera - webex, zoom, ...  rebooted then reinstalled webex and now it is working,.
8 Replies 8
gladysronzales
Community Member
Hello Cisco Community,
If your camera isn't displaying you in front when using a background image or with defocus, you're not alone. Many users have encountered this issue, especially when trying to use features like these in apps such as PicsArt. It's important to troubleshoot and explore settings to ensure compatibility and functionality for a seamless experience....Keep it up.
Best Luck!
dmcinnis
Community Member
eric.dcvieira
Visitor
Reinstall but the problem persists
dtibbe
I've checked here, but I do not have the issue neither in calls nor in meetings. Also I've not heard about that from any collegues.
Is the issue also present if you place yourself in front of another wall? Maybe you're too shiny and Webex does not recognize you in front of the white wall
Is the issue specific to Webex Calling or is is in Calls on Webex or Meetings as well?
I'm going to try to reinstall, I tested the same feature with Zoom it worked
Background removal is done by the app, not by the camera. The algorithms may differ between applications..
I have to reinstall, webex again.. thank you
This was helpful to me.
---Fred Therrien---
