How to Integrate a Website with Webex Meetings
zaeemxyz123
Hey,
I’m working on a project where I need to integrate Webex Meetings into my website riddles to allow users to join scheduled meetings directly from the site. I want the process to be smooth, ensuring users can join with minimal clicks and without leaving the website.
What’s the best approach to achieve this? Does Webex provide an API or embed options for direct integration? Also, are there any authentication considerations I should be aware of?
dtibbe
There is a Webex Meetings Widget available. It is designed for your requested use case. Check out https://developer.webex.com/docs/widgets#meetings-widget-
