Scheduled Reboot - Cisco IP Devices
MTrent
My organization has been on WebEx calling for a little over a year now.  We migrated from on-prem CUCM but have opted to be fully cloud based with our WebEx implementation.
We have seen issues with our Cisco devices (primarily 7841s) having call quality issues the longer they have been running.  Some users are seeing upwards of 30% call legs showing poor quality.  The issues seem to go away after a device reboot.
We'd like to be more proactive about preventing these issues from occurring and reboot the phones on a regular basis.  Based on what I can see in the control hub, this isn't possible.  I know we can reboot one device at a time, but that hardly seems practical in an enterprise environment.
Is there an option to do this that I am overlooking or does it just not exist?  Assuming it doesn't exist, is it on the roadmap for future features?
6 Replies 6
Jonathan Schulenberg
I’m not aware of a bulk reset option - or at least I couldn’t find it in the API documentation
This is not expected or acceptable behavior however. IP Phones should be reliable for years of uptime. If you can identify a correlation between uptime and performance issues a memory leak would be the classic culprit. Cisco TAC is on the hook (with sufficient logs) to find it and file a defect ID so the devs can fix it. Buckle in though, it’s likely to be a bit of a slog proving it.
Thanks.
I figured it would be no quick fix trying to track down the culprit.  I'm mainly looking for a band-aid to buy us the time we would need to identify and resolve.
The thread is over a year old.  Did you ever get a permanent resolution?  We recently migrated and are seeing this issue. TIA.
I never did and the issue persists to this day.  The powers that be have not been happy with the migration because of all the call quality issues.
There is a roadmap item slated for first half of 2025, that would allow a bulk resync of device from Control Hub.
Glad to hear this.
I'm very hopefully it will help the issues we are still seeing to this day.
