Make a Standard Webex without 10s delay
bartounet16
Community Member
Hello I am deploying the Webex calling solution within my company
I would like to do something quite simple when someone calls my switchboard number, it plays an announcement and transfers directly to a number
but I can't do it I have created an automatic standard that plays the announcement But if I put in option 0 "forward to an operator" it works but we have a 10 second delay and a message "your call will be forwarded to an operator"
It works but it is not practical I would like it to read my announcement and transfer directly without having to wait 10 seconds and without hearing a second message other than my announcement
Can you help me??
That could have several reasons: Are the agents available and logged into the queue? As we've been talking about a call forward and some scheduling, is the schedule setup properly?
What happens instead, is the call getting redirected to the overflow target or is the call staying in the queue?
5 Replies 5
dtibbe
If you want to forward those calls to a HG: Why not using the CQ instead? Assign the agents directly to the CQ instead of using the HG additionally.
I also just tested here but I was able to configure the HG as overflow destination for the CQ.
For the CQ, you may configure a selective call forward and assign a holiday/business hours schedule to it. You may also configure other conditions and exceptions when to forward or not. Simply access the CQ's Call Forwarding slide out.
Hello
I don"t understand, using CQ , agent in the CS are not called !!!
why phone are not ringing in my CQ ??
bartounet16
Community Member
.Thank you very much for your help.
I did not know about the queue system It is interesting,
I can indeed get the expected transfer behavior right after the announcement
However, I have the impression that there are limitations compared to the IVR
1 - we cannot send call to a hunt group
2 - we cannot use the calendar to have different announcements depending on the times ?
dtibbe
The Auto Attendant transfer to operator timeout is currently fixed to 10s. I think may people requested to adjust it, maybe such a feature will be available in the future.
But you can achieve the same by configuring a call queue. Set a mandantory announcement. Do not assign any operators to the queue and configure overflow to you desired target number.
