What JavaScript Interpreter does the evaluate node use?
Gerry O'Rourke
the Webex connect evaluate node allows you to write JavaScript code.
However it seems a lot of 'standard' JavaScript is not supported?
Does anyone what version the JavaScript interpreter uses?
Gerry
Gerry O'Rourke
I believe it uses EcmaScript5 - so when using AI to help create JS - ask it to create JS using ES5.
parram2.hhc
Frequent Visitor
Frequent Visitor
Hi @Gerry O'Rourke
I don’t have the answer to your question, but I had the same problem, I resorted to using Google Runtime or AWS lambdas (depending on what the client had) to circumvent the limitations of Webex Connect JavaScript, also I personally don’t like JavaScript and using a cloud 3rd party to run code in more powerful/backend oriented languages ( like: C#/python/Rust) seem more reasonable than fighting with JavaScript and the webex Connect limitations on it.
