Cisco Codec EQ - The USB-C port input audio selection
FrankLiao
Hello community,
I would like to know is there any configuration for Codec EQ USB-C port to select the audio source from the DP signal embedded audio?
I understand that the EQ USB-C port (ALT Mode) is taking the video from DP and audio from USB.
However,
My application is to use a DP-USBC adapter connecting my DP source to EQ USB-C port,
the video passthrough to EQ HDMI output1 is good though, there is no USB host to handle the EQ USB-Audio device.
Therefore, I need the USB-C audio source selected to its DP input.
*ps
The DP-USBC adapter output both video and audio are good at the Dell and Samsung monitors USB-C port.
My EQ software version: RoomOS 11.16.1.7 81e0063ac75
Thank you for considering my request.
0 Replies 0
