CS-TOUCH10+ SNMP
jakiki
Can SNMP v1 and or v2 public community string be disabled on CS-TOUCH10+ device? Can SNMP v3 be enabled?
Thank you.
Igor Lukic
Hello @jakiki,
to my knowledge there is no way to directly configure SNMP settings on a Cisco Touch 10 device. Instead, you can enable or disable SNMPv2 on the connected codec itself.
At the moment only SNMPv2 is supported.
Have you tested turning off SNMP on the codec, to which the touch panel is connected to?
Best regards
Igor
jakiki
Thank you!
Igor Lukic
Hello @jakiki,
Best regards
Igor
