How to disable the Webex Assistant permanently in RoomOS?
gfolens
Level 4
Level 4
In the RoomOS settings you can disable the Webex Assistant: "User Interface Assistant Mode = Off"
But if you then go on the codec/navigator in the settings page as user you can override this setting and enable the Assistant again.
Is there another setting where you can disable this adjustment on the Settings page?
I'd recommend that you lock the settings menu out so that the settings cannot be changed without entering a username and password.
xConfiguration UserInterface SettingsMenu Mode: Locked
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
