01-21-2021 06:11 AM
Hi all, I am using a Webex room kit Pro and it is connected to a Tesira Forte. The Tesira is picking noise from the codec even when i am not in a call, this noise cannot be heard when recording a call be when i play the recording back i can hear this noise. Is there a setting on the codec to stop this?
Solved! Go to Solution.
02-03-2021 09:43 AM
Thanks Sabastian..
07-18-2024 11:22 AM
We have just installed three new Pro devices in a some of our classrooms. I've never run into this with our other units, but on all of these the output (Output 1) sound like a Model T running down the road with an industrial strength bubble maker strapped to it. Ours also are going into a Tesira device. You can only hear it on our recordings, but it is causing all types of hate and discontent in the ranks.
07-18-2024 11:27 AM
Ultrasound got it!
02-08-2024 09:24 AM
We have dozens of WebEx Roomkit Pro units. They all output bad audio out analog output 1. In a call or not. All Proximity and Ultrasound and phantom power off. All sources muted in the Audio Console. The issue is a high frequency distorted static noise. All of our units are doing this. I have recordings to demonstrate. The level of the noise is low enough that most people might not complain, but as a professional I know it's causing fatigue in our learners at University of California.
02-11-2024 03:55 AM
Hi did you get a solution for this as we are having the same issue on the WebEx SX80's connected to a Tesira only started on Friday did Cisco update anything as the Proximity Pairing Ultrasound Max Volume is set to zero which used to be off.
This high pitch whining can only be heard on the recording, not during the live session?
Any help greatly appreciated.
02-15-2024 07:33 AM
Cisco sent me instructions (below) but the issue remains.
Let’s try the following for ultrasound:
Please go to the endpoints UI and go to: Standby > WakeUpOnMotionDetection
Please check if that’s off, if not, please turn it off, and reduce the ultrasound “Max volume” to 0
Don’t forget to click “Save” so we can have that configuration applied.
If the ultrasound keeps activating, please use the following command:
*c xConfiguration RoomAnalytics PeoplePresence Input Ultrasound: Off
07-18-2024 11:28 AM
Ultrasound MaxVolume took care of ours! Thanks.
02-13-2024 07:41 PM
You should be able to turn Proximity Off completely via the web interface rather than just setting the max volume to zero.
It would probably also pay to add a low-pass filter to your Tesira for the input that the codec's output is connected to, to drop the ultrasound frequencies that Proximity uses so they don't end up at your recording solution.
Please remember to mark helpful responses and to set your question as answered if appropriate.
02-14-2024 01:47 PM
Thanks Wayne
02-03-2021 09:43 AM
Thanks Sabastian..
02-02-2021 06:26 AM
Does the Tesira require power from the codec? If not you should disable the phantom power from the inputs.
Audio Input Microphone [1..8] PhantomPower
Define whether or not to have phantom power (48 V +/- 1 V) on the microphone input.
Requires user role: ADMIN, INTEGRATOR
Default value: On
Value space: Off/On
Off: Disable the phantom power on the microphone input. Use this when connecting to
equipment that do not need phantom power, such as external mixers.
On: Enable the phantom power on the microphone input. Use this when connecting
directly to microphones that require phantom power, including the Cisco Table
Microphone and Cisco Ceiling Microphone.
