SX80/Webex Room Kits
Seoulhawk
I would like to find out if there is a way to set network port #2 (I use it for the Touch 10) to a static IP? The network that I am using is DHCP but from time to time the system will not pull an IP. With the most recent versions of CE I have discovered that when the SX80 does not pull a DHCP IP that touch 10 will go into a boot loop or just will not find the SX80. I thought I would see about configuring that port to be static so this should not be a problem, but cannot find any documentation on doing it.
Any ideas?
0 Replies 0
