Showing results forĀ
Search instead forĀ
Did you mean:Ā
USB Ports on Room Kit, Room Kit Plus and 70D
We work with a client that has a number of Room Kit, Room Kit Plus and 70D systems. The camera units on each of these have USB ports on them. Does anyone know what they are for? (excluding the ones that are labelled for service) I cannot find any notes on what these are used for at all.
What our client would like to do is create a BYOD solution using them with a USB connection to the camera unit and then an HDMI to the screen in the room.
Many thanks in advance.
GAM
Buena tarde, saben si a la fecha aĆŗn no se puede ocupar los puertos USB para modo BYOD?, Gracias.
If I should guess.. "future use"... If you want to use these systems as a BYOD-solution, you would need a USB-capture device like Inogeni 4KX-Plus. If you want to know more about the USB capture-functionality, see drawings and download macros for this, visit this webex space:
PROJECT: USB Mode (External) - JOIN via https://eurl.io/#L6Rcn39Rn
