I see in the latest Webex Board Pro admin guide it has a 2nd network port with Touch and Camera icons on it. Does this means you can connect the Webex PTZ 4K camera to the Board? Which input do you then use for the HDMI output from the camera? The HDMI input or the USB-C? In the latter case I suppose you need an adapter.
Is this setup supported by Cisco?
