Webex kit pro
AjithAnanthakrishnan
Community Member
1)If we connect a Third part camera to cisco webex kit pro will it work ?
2)Do the camera HDMI port in the kit will  active without control cable connected ?
Matt_W
Level 8
Level 8
You can choose if you want the input to be Camera or multiple other types of options. (See Attached Image) Just keep in mind, camera control will not be supported from 3rd party cameras and you will need to support the camera control through another system.
You can also check out this link for a similar thread.
Solved: Webex Room Kit Plus and 3rd Party IP Cameras - Cisco Community
