Webex Room Kit Plus configure mono audio out out?
efransen
Webex Room Kit Plus. This unit has a 1/8" mini stereo audio output. Can this output be configured to be a mono output?  Some audio gear mono signal is on the left channel. Is there perhaps a mono signal on the left channel?
Thanks for you time,
The Room Kit Pro is a device that has the ability to set a mono output if that is helpful in deciding which device to purchase to meet your requirements.
The Room Kit Plus does not have the ability to set this, you will need to do a mix on external audio equipment to get a mono output.
In general, audio from the participants in the meeting will be mono anyway - it's just any content that is fed in to the system that may be in stereo, so depending on what you are trying to achieve, the standard output may be alright for if that matches your requirements.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
