API to get/set General template applied and Emergency Callback Number
simonunivonix
Is there a Webex API to get / set the following settings for a given user:
  1. General template applied.
  2. Emergency Callback Number.
  3. Music On Hold
Simon
simonunivonix
I found item 3 "Music On Hold" - /v1/telephony/config/people/{personId}/musicOnHold.
Still looking for the other 2
Not sure what you mean when saying "General template applied", do you mean how a user is created or something else?
As for Emergency callback number, we have API for GET/Update a location's ECN, see below. We don't have any API for this at user level though.
https://developer.webex.com/docs/api/v1/location-call-settings/get-a-location-emergency-callback-number
https://developer.webex.com/docs/api/v1/location-call-settings/update-a-location-emergency-callback-number
From the Control Hub, in the user>calling section, it is possible to set the ECN to one of following.  Can this be done via the API?
  • User's phone number
  • Location default ECBN
  • Assigned number from user's location
There is no option to do this through API at user level currently. It's planned for the future but no timeline set yet. You may create a feature for it here; https://ciscocollabcustomer.ideas.aha.io/ideas, to show the interest on having this feature implemented.
