API webex event (template and call in )
Pierrick
Visitor
i'm trying to use command API to create webex event but i'm blocked to :
Use a template. I try to use this argument but not recognize :
<templateType>template custom</templateType>
I tried to use this site but don't know in which paragrapher this argument should take place.
https://developer.cisco.com/docs/webex-xml-api-reference-guide/#!elements-in-webex-xml-schema-definitions-for-the-event-session-service
here the code :
____________________________________________________________
<?xml version="1.0" encoding="UTF-8"?>
<serv:message xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<header>
<securityContext>
<webExID>XXXX</webExID>
<password>XXXXXXX</password>
<siteName>XXXXXX</siteName>
</securityContext>
</header>
<body>
<bodyContent xsi:type="java:com.webex.service.binding.event.CreateEvent">
<accessControl>
<listing>UNLISTED</listing>
<sessionPassword>XXXXXXXX</sessionPassword>
</accessControl>
<metaData>
<sessionName>Event name</sessionName>
</metaData>
<schedule>
<startDate>12/1/2020 18:00:00</startDate>
                <duration>45</duration>
               <entryExitTone>NOTONE</entryExitTone>
</schedule>
<event:extOptions>
                <event:registration>false</event:registration>
</event:extOptions>
<telephony>
                <telephonySupport>CALLIN</telephonySupport>
                <muteUponEntry>true</muteUponEntry>
</telephony>
</bodyContent>
</body>
</serv:message>
Thanks in advance for your help
Gasper A
Hello, templateType specifies the type of template to be used. Valid values are "user" or "site". You do not need to include this parameter, or you could use the createEvent session example here; https://developer.cisco.com/docs/webex-xml-api-reference-guide/#!createevent/createevent
Gasper A
